So I have been messing around trying to figure out why the remote access does not work.
Yesterday I even changed something I could not reverse internet stopped working and I had to buy a new router today. I tried everything assigning the static ip, port forwarding the port that plex tells me to, setting firewall from the router off, stopping windows defender firewall, avast… etc…
I don’t know what I’m doing wrong …
Today I bought the Motorola AC1900 modem router combo (I’m using the nvidia shield tv for the server and comcast is my provider) I set it up and everything was green and working for the first time. But when I went back to check it again it was not working, when I try to set it up it always goes green for a second and then back to red.
protocol should only require “TCP”… however it’s unlikely restricting this will suddenly enable the remote access.
you should contact your ISP and ask them if they apply any restrictions from their end.
Is it normal that the IP address in Plex where I enable or disable remote access is different from the ip address that I get when I type Ipconfig on cmd?
3 IPS:
192.168.0
Default Gateway is the same changes the last number
Ethernet Ip: 10.177.45
SA200 I don’t really know how to check that.
You should be able to check the Nvidia Shield local IP to confirm it is the same as the IP you have setup the port forward to 32400 to.
Once you know what it is and the port forward is setup correctly to that IP, then you go into the router’s DHCP Settings and make sure this IP address which is 192.168.0.x (you need to check if it is 192.168.0.12 as per your port forward), is setup as a DHCP Reservation. The router user manual should tell you how to do that. The alternative is to set it up as static and have the DHCP Range adjusted - eg (example) - static IP Addresses between 192.168.0.1 and 192.168.0.49 and DHCP Range set to 192.168.0.50 to 192.168.0.253. I always use DHCP Reservation so it is within the DHCP Range but reserved for the Mac Hardware Address of the Ethernet card
@Sergio1535 said:
Canyouseeme I realize it changes if I have my vpn on or off on my laptop
Off: 24.127.162
On: 45.56.154.15
Normally remote access settings do not work when vpn in use as it adds another layer.
