Remote Access Not Available outside your Network - Already Set up Port Forwarding, No Luck!
Server Version#:1.31.0.6654
What’s happening: Plex was able to connect remotely for years just fine. Now it’s not able to and limiting the quality of the videos outside my network. I’ve tried port forwarding after setting up a stating IP address for both my router and my server.
I’m not sure exactly what happened or when it happened to cause this but I have a theory about it potentially being attributed to wifi extenders that frontier installed by eero. This could be a router, I’m not positive. However, I have set up the router/extender to a static ip and port forwarded it as well.
Any luck would be greatly appreciated. Thank you in advance!
My plex server suddenly in the same posiiton, no remote access, but been fine for years, port forwarding setup, it says it can be accessed externally but can’t access it externally
Start here The Basics of Remote Access Troubleshooting
ISPs may also change policies regarding Carrier-Grade-NAT on existing accounts.
You might wanna enquire with your ISP.
It is strange as I have 3 ISP’s and I’m having the same issue with all of them
I have two ISPs and its the same, ended up going back to an older version of plex and now had remote access back for over 24 hours.
