Server Version#: 1.15.6.1079
Player Version#: 3.95.2 (latest as of June 9, 2019)
That’s a lot of logs!
But you could just tell us what steps did you take? So the problem can be narrowed down a bit. It’s hard to identify the problem if we don’t know what exactly we’re looking for.
A quick look at your logs shows there’s problem with UPnP with error mapping port, and losing connection.
Did you manually specify the port? or did you leave it automatically to port forward for you?
If automatically, does your router support UPnP? Is it enabled?
