Remote access Not Work againt variant
now the local and external ip disappeared, after downgrading and updating to the latest version.
please help me
Server Version#:
Fixed, I returned the plex media server to version Version 1.20.4.3517 from 3616
and the 3600 which has caused a lot of problems.
I solved the internal ip thing by activating advanced options.
At the moment the error is solved, I do not expect to update more until they really convince me to do a healthy BUILD and not to put myself in the dark.
Thats not a solution, it’s a workaround…
How did you downgrade your version? Did you remove and re-install?
On MacOS I just dragged the old applikation to Applications.
On Windows 10 i had to cleanout registry and %localappdata% aswell before installing the old version.
Is upnp enabled in your router? What OS are running the server on?
Sure! cleaning registry, uninstalling version and install old version in local/appdata/plex media server/VERSIONS. thank you.
uninstalling version cleaning registry, (restart PC) and install old version in local/appdata/plex media server/VERSIONS. thank you.
Error again
