I have plex server installed on my WD PR2100 it was working perfectly until recently I cannot access remotely, my home wifi is through Linksys model WRT1900AC, I access my plex from my MacBook running Mac os Catalina.
FYI, I am not expert, but I have read allot of threads, tried accessing my Linksys, did port forward and still not working. watched so many videos, so many trials all failed.
May anyone please help me with the issue, with simple illustration
I recently fixed a similar issue with my server by doing the following:
delete current port forwarding rule from router
in the remote access settings clear the specified port and checkbox for “Manually specify public port” (if set)
disable remote access
enable remote access
In my case this automatically created a new port forwarding rule on my router, on a different port from the one I was previously using. Checking via canyouseeme went from timed out (original port that had been working fine for months) to success (new port related to automatically created rule).
Agreed. Unfortunately my manual port forward that had been stable for months, stopped working recently and resisted other resolution attempts (I stripped out the rule and started from scratch with no luck). So this was the only thing that worked for me to get remote access back.
Does your router support upnp? Did a new port forward rule get created automatically? If so you need to test the port from that rule rather than 32400.
I had this same exact issue. Worked great for a year, then nothing. I updated the firmware on my router, updated the server and it seems to be ok now. Maybe see if your firmware needs updating?
