Server Version#: 1.43.5.11079-b3b13e506
Player Version#: Plex for WIndows 1.115.0.426-4e960a1d
It was working totally fine until recently. No changes were made on my end. Not on a VPN at home, my DNS on all my devices including server is set to google (8.8.8.8). Tried restarting router, checking port forwarding, stop plex server and redownload certv2 file. My server itself shows that remote access is available but none of my clients connect. Sometimes they do but indirectly with conversion, and sometimes when they try to play directly it takes minutes to try to load only for me to get an unknown error: 4294967283. Log file attached. Thanks!
Have you signed out and back in on the clients that aren’t working to ensure they pick up/refresh any changes you’ve made to the cert and/or port forwarding rules?
Assume you’re manually forwarding and not relying on UPnP?
In your plex network setting also uncheck “enable relay” so clients can’t connect indirectly.
Enable Relay is now disabled. I signed out of the windows client and back in. I already had cert-v2.p12 so I didnt need to redownload that. Manual port forward since my router doesnt have UPnP. Host port 32400 with a global port range of TCP above 45000. My server has an allocated static IP as well. Still same issue. My server shows remote access green but my client shows remote access available for like 20 seconds then goes back red. Same unknown error code when trying to play anything.
You mention setting a port above 45000, but logs show 32400 or 32420 as the port you have set in plex.
If you’re referring to the Remote Access page in Plex, this is how the page behaves when it’s testing remote access. It will show green and then flip back to red when it’s not configured or reachable.
Ive attached the requested images. I was referring to the remote access page from within my client. In PMS it stays green and is fine, but when i try to connect in client it’ll show working for a bit, but then change back to red.
also canyouseeme shows my port 45420 is open successfully.
Can you clarify if this is actually remote access you are trying to troubleshoot or local connections on your network? I’ve had some folks refer to connections not on the local server, in their own home, as remote, so just checking.
There’s an issue with the BGW620, so trying to see if it’s the same issue. Basically if you have a port forward and remote access enabled, local devices won’t connect. Some have sporadic success, but it is causing issues.
Off your network, if you try to reach http://<public-ip>:45420/web does it connect to your server? It doesn’t resolve for me, which points to the same gateway issue..but not 100% since would need you to confirm. The issue started about a week ago, so would line up to when you started having issues.
Odd that 45420 doesn’t show in your logs as a port you had set when you grabbed the logs. I’m not great with logs, so maybe I’m missing it. Did you change it since you grabbed them?
This is indeed remote access. Everything been setup exactly the same for years with no changes and had no issues until about a week or two ago. I edited my previous reply with the new logs since changing the port that was my bad.
I tried to access the public-ip:port/web on my phone while disconnected from local network and it just keeps saying connection reset. So I’m guessing its an issue specific to my modem/router then? But the timeline certainly lines up it’s been happening for like a week.
Going to assume it’s a similar issue then…usually it only works locally or only remotely when a port is forwarded. But you seem to be having a slightly different experience.
Best solution right now is to get your own router and put the att into passthrough. Here’s a comment I left on another post with links to similar issues. The last one is to a post on the att fiber sub Reddit where someone noted they reported it to AT&T, but not sure what will come of that..
Gotcha. Had a feeling it was something to do with ATT cause it was strange how it happened suddenly. Thanks veejay! Looks like I’m getting a new router.
