Remote Access - OMV
Server Version#: 1.18.0.1892
Had no problem with remote access and recently moved. Remote access worked for one day, perfect, until recently. Now I can’t get it to stay green. Have rebooted the server, the docker container, and the router/switch multiple times with no luck. I have also logged in and out and forgotten the server many times as well.Uploaded the server logs. I stopped docker image, deleted the Preferences.xml, and restarted the image as I saw this worked in another post, Plex Media Server.log (3.0 MB)
do you have a port forwarding setup?
Yup, have port forward to 32400. I’ve tried to connect with it on and off, and am getting indirect connections (occasionally). Other times it doesn’t work at all.
Check canyouseeme.org for success on your port.
I checked this evening and there is no access via canyouseeme. I’ve rebooted all my network equipment in the past, worth a shot to try it again?
Please post details about your port forwarding.
Screen shots excluding public IP info.
Sure! I have a dual ethernet card in my NAS on two different networks. I have two sets of port forwarding rules that address all the ports for these internal IPs. I had some remote users do troubleshooting for me last night. They are able to connect to the Plex through a device such as their iPad, but they cannot connect to it through their TV.
from what I have seen multiple NIC devices are nothing but trouble for remote access.
Have you set this option to the NIC you want to use?
not sure why anyone would run a dual NIC setup like this but everyone always has their reason.
I would suggest you get rid of one NIC and see if it stabilizes.
Yup, I have it on the 192.168.3.74 card. I’ll try, though it was working just fine until a recent update to the server (beta channel). I believe it was the first .18 release.
I Have Been Having Trouble Keeping Mine Available Outside Of My Network!
Seems That The Plex.tv Server Just Randomly Decides To Take My Server Out!
I May Work For A Week, A Few Days, A Few Hours, A Few Minutes Or Not Even Last A Minute!
I Reset & Reset & Reset & Reset & Finally Back Online!
Then It Is Taken Back Offline! Nothing Has Changed On My Server And My NightHawk Netgear Router!
I Have Frontier FIOS 500/500 Internet Service!
It Has Ran Fine For 4 Years! Now For The Last 3 Months, I Can Not Trust It!
These Are Not User Side Issues; These Are Plex Software Issues!!!
