Remote Access PMS 1.6.1.3772
Help! I’m unable to access plex outside my network. I havent had any network changes or system changes. Running MacOS 10.12.4. Not sure whats going on. Has anyone else had this occur on this version of PMS?
Did you check if your router got an automatic update and reset some switched? Since you are not using a manual port, make sure your router has uPNP enabled.
