Remote Access Problem - 10% of the time it says online 90% of the time it says offline
Server Version#: Version 1.25.2.5319
Player Version#: Any
Windows firewall is turned off
Router has 32400 and 80 open
Settings are
Private 192.168.200.35 : 32400 Public 188.232.65.67: 80
90% of the time remote access says Not available outside your network 10% of the time it’s green and available.
I do not have double NAT and I have no internet restrictions or issues.
This baffles me a great deal as no matter what I seem to do I cannot get this fixed.
Can someone work with me to get this resolved please, thank you.
Given that the remote access status indicator can occasionally be off… can you access your server from outside your home network despite it saying it’s offline?
If it’s not actually working… can you access your router’s public IP on tcp 80 from outside your home network (e.g. using a service like canyouseeme.org)?
It’s not occasionally off though it actually says not accessible outside your network 90% of the time. However, I can access it from outside every time as can any other user. There are some times however that the plex relay service is running and times it’s not. I can access my router’s public IP on tcp 80 from outside my home network 100% of the time. This issue is beyond my understanding. For the life of me I cannot figure out how to fix this so it always says remote access is good (even though it is always good) but plex rarely states that it is.
Thank you for your response It is my hope that you or someone can really help me to determine what is causing this and get it resolved, Thanks!
There’s times when the server fails to verify that remote access is working. Don’t worry too much about the status indicator… if it’s actually working, that’s all that should matter.
