The firewall on the machine running the Plex server is not on but the one on my router is and is set to allow all outbound traffic but only allow inbound for that which was initiated from an internal I/P address. I was using Jumbo frames and I read where that could cause Plex some trouble so I shut that down. So far it’s been running but we will see.
I have the same issue. Remote Access works fine for a few hours, maybe a day, then for some reason becomes "unavailable:. Once I shut down the server and restart it, remote access works fine again for awhile. It’s setup on a windows 10 box with the port manually specified to 32400. Any suggestions?
Same here, this is super annoying. Never happened until version 1.0. Each morning I gotta restart the service basically. Users are dropping like flies due to this
Problem still there and since we can’t downgrade due to downloads being removed this need to get addressed asap. I’m connecting fine to my server directly - using public ip and port 32400 just as it always has, and can through there make the plex service realize it should work fine - which it then does for some time until it breaks down again. So my port is ofcourse mapped just fine manually. The problem is elsewhere. Who got the amazing idea to remove the older releases before testing 1.0? Does anybody have 0.9.17.2 for ubuntu 64bit available?
I’ve tried disabling the UPnP port on the modem, but that doesn’t seem to help either… I was having issues before the upgrade. If there is any idea on why this happens it would sure help a BUNCH of us out…
