Server Version#: 3.108.2
Player Version#: Web Player
Hi so i have been setting up my plex server and my remote access will randomly disconnect and im not sure why.
I am hard wired in
Ports are forwarded
Ip is static
it worked for like 3 hours then stopped
Xfinity is my provider and i have the xfi stuff if that helps
Have you confirmed your port forwarding works at www.canyouseeme.org?
Did you actually lose connection or did the green just turn to red in the remote connection screen?
I’ve heard of this happening a lot and it happens to me all the time: the green turns to red and says no remote connection, but it works fine from outside my network. I think it’s a bug - I’ve seen posts about this problem over a dozen times…
I have the same Problem. My Xfinity Modem has gotten replaced recently and after it had gotten replaced my external network card wouldn’t connect. So I had to go to my onboard network port and now like you my Port Forward is giving me the same problem.
It will connect for about 15 min and rapidly disconnect…
I am able to get a connection to my server from my Cell Phone and Smart TV but others that I am sharing with cannot
