Server Version#: Latest
Player Version#: Latest
Ever since I switched to AT&T Fiber, my remote access has been giving me a lot of problems. I cannot seem to figure out what to do with my modem admin page to help this. Someone please help!
Plex Documentation
→ Remote Access
→ Troubleshooting Remote Access
Plex Forum Tips, Tricks, & How-Tos
→ The Basics of Remote Access Troubleshooting
I’ve AT&T Fiber with their BGW320-500 router. Plex server is connected to router via Ethernet cable.
This works on my system:
Note: The AT&T router does not support UPnP. A manually specified port must be used.
Login to AT&T router, http://192.168.1.254.
Go to Device → Status
Under Home Network Devices, make sure your Plex Media Server is listed. Note the name (the router lists my PC with a name different than the actual hostname).
Go to Firewall → NAT/Gaming
Create a custom service for Plex.
Click on Custom Services button. This brings up the Custom Services page.
Assign service to your Plex Media Server
In Application Hosting Entry section
Service = Plex
Needed By Device = Your Plex Media Server
Click Add
You should now see Plex listed as a Hosted Application.
Login to your Plex Media Server.
Settings → Remote Access + Show Advanced
Enable Remote Access (it will fail, which is OK).
Check the box for Manually Specify Public Port
Set port to 32400.
Click Retry.
You should now see Fully Accessible Outside Your Network.
The Remote Access page will show the IP address of your Plex server and the public IP address from AT&T.
You can check that the port is open.
https://canyouseeme.org
Your IP should match the Public IP on Plex Remote Access page.
Change port number to 32400 and click Check Port.
If the port is open and your PMS is running, it should show success.
That seemed to have done the trick… Confirmed by two different users. Thank you so much for your help.
