This just started a day or so ago, my server is showing that it’s not available outside my network, but I know for a fact that it is working.
I do use a custom access URL and looking in the logs it appears that the connectivity checker is going directly against my public IP address which will not work. The only way to my Plex server from the internet is through my custom access URL. It (the connectivity check) used to work a few days ago. Did something change?
It’s a known disconnect between Plex/Web and the server. It’s been written up and submitted to the Devs.
My advise is to not touch it if you can help it. There’s a disconnect in the sync logic where Plex/Web, PMS, and Plex.tv get ‘locked’ and can’t get ‘unlocked’.
Yes, the correction was put in place and released.
I recommend a manual ‘cleanup’ of your Preferences.xml file to get this kick started again. (where things went sideways between it, plex.tv and the DB)
When you start it, it will inform you there is an “Unclaimed Server”. Ignore it (click the X in the upper right).
Continue on into the server.
Settings - Server - General and sign the server into your account.
Settings - Server - Remote Access and complete the reconnect.
