Remote Access speed vs Plex Web (Internet Streaming)
I have located two spots in the plex settings where speed/quality can be changed/set and I’m not sure which one wins/overrides/etc…
The two locations that I found are:
  • Plex Web, Quality, Internet Streaming video Quality
  • Settings, Remote Access, Limit remote stream bitrate
Is the remote access option simply for setting a limit and not necessarily forcing a quality setting?
Also, under the remote access option I can set the bitrate to Original (no limit) and has 4k options whereas the Internet Streaming setting can be set to Maximum (no 4k options).
Thanks.
The first is the setting for the client (Plex web is a client), the later is for the server.
Ok, that makes sense. Do I have this correct…
  • when viewing on my laptop via the browser I would check the settings for Plex Web?
  • when viewing on a client device, tv app, xbox app, phone app, nvidia shield plex app I would want to check the settings under Remote Access (even though I may not be remote)?
Also, why does one have a 4k option and the other only says maximum?
  1. Yes
  2. Only applies for remote. Local network is not remote. For that, there is no limit.
Regarding number 2, I thought so, but wanted to confirm, thanks. Meaning, those apps still apply for number 2, but only if they are not on the same network as the plex server. If I have a shield connecting over VPN, for example, back to a server, I’d still want to check the Remote settings. Although, when I test this, I still had to manually set the playback speed on the remove plex app, which is not a problem, but it didn’t seem to adhere to the remote access speed limit of 720p.
No, VPN is regarded as being local. VPN is a tunnel into your local network. The device temporarily gets a local IP
Not true in my case, my VPN is site to site and the nvidia shield running as a client gets an IP from subnet A and the plex server is on subnet B.
True, then you are correct.
Ok, thanks. Nothing on the 4k vs maximum? Not a big deal, just curious. I assume maximum will make the best attempt to possibly play at 4k, if possible? Or is the web app not capable of playing at 4k? I’m not sure if 4k is also limited to the web player and the screen resolution, aside from network/internet speeds. In my case it doesn’t matter because my upload doesn’t exceed 10 Mbps, which is my restriction point when remote/VPN, but it would still be good to know why those settings don’t match.
Appreciate the quick replies.
I have no clue :smiley:
Ha, ok fair enough.
