Just what the subjects says. Everything was working fine, has been working fine, then the other day I was suddenly unable to access plex remotely from any of my apps. It happened while I was away, and nothing at home changed. When I got back, I rebooted everything, checked all my settings, nothing has changed. I called my ISP, they do not have CGNAT activated.
My setup is that I do have a VPN on my router, but my VPN allows port forwarding and so I have had that all properly set up for a while now. No idea at all why it would suddenly stop working. Any suggestions where to look?
I suppose that I should add that the error I was getting from the app was that I couldn’t get a direct connection to my server, so it was sending me through the relay. Then it wouldn’t even load the home page, plexamp also stopped working.
UPNP is turned off on my router.
