Remote Access Throttled under 2Mbps - 1.31.0.6654
Been having issues this week with remote access, and it looks like anything over 2Mbps just crashes and burns.
I have a 20mpbs upload on Spectrum, and my test cases have all had 500Mbps or better download speeds.
I have not made any changes to my network infrastructure, and my media is stored on an Unraid NAS connected via 10gpbs to a Mac mini server currently running Plex 1.31.0.6654.
If I force transcoding on either the Mac mini or the client to 2Mbps, I’ll get a little buffering up front and then the files will play, but if I leave it as direct play or transcode quality higher than 2Mbps, all remote clients will buffer. No issues with local clients on the same network.
Any thoughts?
Thanks, I’m manually port forwarding and the IP’s look good.
Upload speeds outside of Plex look solid (I ran a few Aspera transfers to confirm there wasn’t an issue with my upload connection) and I’m able to hit 19-20 Mbps.
How is that remote stream of yours listed on the Now Playing section of the server’s dashboard (remote vs. indirect)?
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
Remote. I confirmed that I have Relay disabled on the server as well.
I’ve been having the exact same issue. Server is 1gbps up, and client connection is 25mbps down. Relay is disabled, yet still throttling to under 2mbps in most cases.
Have you checked the client remote streaming quality settings?
Yes, all set to maximum. All are AppleTV or FireStick. Media is pretty straight forward mkv with Dolby Digital 5.1 audio, h264.
Issue appears to have been resolved for me since updating to 1.31.1.6716
I have the exact same issue. Not fixed with latest update. Any news on this?
Have you gone through the various troubleshooting steps discussed in this thread and to what outcome?
I think I found the issue. I had activated QOS on my router to prioritise the Plex Media Server, but it seems it actually made remote streaming slower.
