Remote Access To 2 Servers
Hi, I’ve just moved to Sky Broadband. I’ve set up the port forwarding for one server and it works fine. I’ve tried to add for the second server and it doesn’t work. I copied the settings on the router, using port 32401 instead of 32400 and changed the public port on the Plex Server. I must be missing something somewhere as I just doesn’t work.
Server Version#:
The internal port is 32400 for both servers. The only port that needs to be different is the external port
I think where I am struggling is I don’t see where I can map the external and internal ports on my router.
You could check out https://portforward.com/router.htm if there’s a listing for your router (or a similar model from the same manufacturer)
Not to worry UPnP has kicked in and it’s all working. It hadn’t done that last night.
