Remote access using Amp IP address
Since the last update, when I go into the Remote Access setup within the Plex server, the IP address that is being picked up (15) is the IP address of my Sony Amp. It should be picking up 18. I have port forwarding to the server running on 18, but I’m not sure why its picking up 15?
Hence the server is reporting that its not accessible outside. This has been working for months and nothing has changed on the router side or my Plex server which runs on a Synology NAS.
Any suggestions would be much appreciated.
Looks like removing the “manually specify public port” fixed the issue? Bit odd as I’ve always had this switched on with port forwarding in my router.
