Server Version#: 1.41.7.9799 on Synology DS423+
I have configured remote access to use a custom wildcard certificate provided by Let’s Encrypt following Plex own instructions, but if I connect to https://plex.mydomain.com:32400 the page is loaded with a certificate whose CN is for *..plex.direct
If I check the console log I receive the following error:
CERT: incomplete TLS handshake from [::ffff:192.168.254.1]:62481: sslv3 alert certificate unknown (SSL routines)
I have created the PKCS12 file with the following command:
openssl pkcs12 -export -out file.pfx -inkey PRIV_KEY.PEM -in CERT.PEM -certfile CHAIN.PEM -password pass:OnePassword
I have read that it’s possible that there’s an error with the chain, but I have tried the fullchain.pem file and the result is the same.
I can provide logs if you need it, but I don’t know what more can I do to solve this.
Thanks in advance and best regards
