Server Version#: 1.21.3.4046
I am having a problem with remote accessing my plex server on my pi 3B.
My wifi is setup a little different then it usually is. I have my main router that is hooked up to a small router in my room, this is connected via an ethernet cable and the pi is connected to that one.
I have port forwarded the correct port and protocol on my small router in my room.
I’ve also tried port forwarding on the main router with the IP of the small router with the same ports, but that doesn’t change anything.When I try to see if remote access works in the settings tab, it says it does work. But on my phone, it does not work. And when I change tabs in the settings, the check mark changes to a exclamation mark. The server works fine in my local network.
I hope this can be resolved. Thanks for the help and answers already
