Hi all
I am having problems setting up remote access.
I have been running Plex Media Server for a couple of year with remote access with no issues. A couple of months ago I changed my computer for a significantly more powerful one, trouble is the new computer wont allow me to turn on Remote Access.
I have gone through the trouble shooting guides, I have checked Firewall settings - I have tried temporarily turning off both firewall and antivirus, I have looked at the router settings and toggles the UPnP settings but nothing makes a difference.
The router is the same one that I had the old computer working on.
I connect to the router via Ethernet not WiFi.
When I try to use Plex on my Fire TV (connected to the same router) I often get the message that I am not connected directly to the server and that playback may be affected. I usually have to go into settings on the Plex app on Fire TV and turn the settings down in order to get smooth playback.
My connection is IRO 250 meg connection.
Any suggestions - I haven’t got much hair left!!
Cheers John
