Ok here go’s. This is what i would like to do. I have 2 computers one is my plex server and the other is my htcp. Is there any way of update libraries from my htpc? Don’t want to keep going to my plex server to update.
Thanks.
Thanks.
Open your Plex server from a browser on your HTPC and then update your libraries from there.
I actually almost never even access my Plex server from the device it runs on. It is easier and faster to access Plex from my daily use computer.
I do not currently use an HTPC but, when I did, I was able to log onto my Plex server from the HTPC using a browser and then do whatever I wanted/needed to do.
You might as well use your mobile phone or tablet.
Some Plex clients do allow you to trigger a library scan. Look in the ellipsis menu of your left side bar items.
