Remote watch pass required for local network
Server Version#: 1.43.2.10687
Player Version#: VIDAA 5.94.1
Recently downloaded plex on my TV and first used it to access a friend’s server with his remote watch pass. Then set up my own server on my PC, logged in, and when I tried to watch from my TV (running plex for VIDAA) it said I needed a remote watch pass. My TV and laptop are on the same local network, and I am not a very computer savvy person so the router is straight out the box with standard settings.
The first 3 numbers on the IP addresses for the PC and TV are the same. I have a VPN on my PC which I think may have been switched on when I downloaded PMS and logged in for the first time, but is now switched off. I’ve been trying to troubleshoot this for hours - accessing router settings etc. Downloaded Plex on my phone, which does have a VPN on it, and can access that just fine with VPN on and off. Checked my browser settings, checked my network settings, tried adding the TV IP address to Plex custom server address/local auth… basically everything that pops up when you google the title of this post. Can anyone help with what I might have done wrong?
This post in the tips & tricks section might give you some pointers on why the tv app considers your server to be remote.
I’ve tried a lot of the tips in there and it’s made no difference unfortunately
Which steps, specifically, did you try? Arguably, the most important one is to ensure that you’re using a DNS server which doesn’t restrict private IP addresses (DNS rebinding protection). There are specific steps you must take to mitigate this. The most straightforward is to ensure your clients use a DNS server which isn’t your local router (like 1.1.1.1 or 8.8.8.8).
Definitely steps 5-7 and 11. I was having a go at step 10 but got nervous about editing the port forwarding settings on my router and called it quits for the night. For steps 1-4 - I don’t think I’m using containers from what I could tell via Google. Was pretty sure about DNS rebinding but could be wrong. No other router-type devices, and I think my IP address is within the home network range (it’s 192.168.1.xxx) on each device.
Apologies for being a complete computer idiot but what exactly is the client? Is that the TV? I had a go at changing the DNS settings on that (changed DNS 2 to 1.1.1.1) and changed the DNS provider on chrome to cloudflare but that made no difference. I could try changing DNS 1 on the TV in the morning if that is what you mean?
No worries! Yes, the client is whichever device(s) from which you’re attempting to reach your Plex server. It could be a TV, a web browser, whatever.
If you can change the primary DNS server on your TV to 1.1.1.1 and restart the TV, that might help.
For some background, the way Plex works for server discovery is to perform DNS lookups on connection information your server publishes to its (Plex’s) servers. DNS rebinding protection prevents lookups for host names to be resolved to local addresses. This forces Plex clients to attempt to use the public connection information, if it exists. This results in connection attempts appearing to be from remote sources, hence the error.
Public DNS providers, such as CloudFlare and Google, don’t impose these restrictions.
Its actually easier to set the DNS settings at the router level. That’s what I do. Google & Cloudflare are good choices. I’m using the Adguard public resolvers myself.
That’s my general recommendation as well.
Default DNS on clients are normally Auto so it best / easier to update router.
I would also recommend setting up reservations for LAN IP’s for your main clients in your router.
Holy crap, I owe you my life. I just changed the primary DNS server to 1.1.1.1 and now it works!! Thank you SO MUCH. Are there awards or something that I can give you??
You’re welcome, glad you got it working! No awards, the “thank you” is plenty.
This has happened again… and now it’s spread to my phone - all on the same network as before, but now I need a remote access pass to watch on both my TV and the android app. I don’t know why because everything worked perfectly yesterday, but somehow overnight it’s all stopped working. I changed the DNS settings for my TV and for my router, tried 8.8.8.8, 8.8.4.4. and 1.1.1.1 but none of them are working…
I was having a lot of problems getting online earlier too, kept getting playback errors and my server wouldn’t load for ages too. Is this maybe an issue with Plex rather than with my setup?
I am having this same problem. Yesterday Plex was working fine on my Roku. I paused the show to go do something and when I came back and hit play, it says I now need a pass. I didn’t change anything. I have restarted both the Roku and my computer. I have unloaded and reloaded software on both devices. I have tried all of your “fixes” above and nothing is helping. My computer in the next room cannot seriously be considered remote. I believe that Plex is the one that broke something. Will there be anybody looking into this.
Same issue here. First happened a couple of months ago, resolved itself after a couple of restarts. Now happened again - literally stopped playing a movie I was watching and then asked for a pass because supposedly I wasn’t on the local network. My phone reaches the server locally so the issue isn’t there. Tried everything absolutely nothing works. I’m on FireTV.. can anyone help?
