Remove 2FA
Server Version#: 1.22.3.4392
I have a QNAP NAS with Plex Media Server installed on it. My system has worked fine for several years now. However, I tried to add the two-factor authentication and something went wrong. The process was never complete but is now listed as “active” in settings. When I try to update this or remove the 2FA, PMS asks for a verification code. Since this was never set up during the 2FA process, I am locked out of making this change. I have mislaid the codes that came with my PMS setup and cannot re-set the program in that way. Does anyone have a suggestion on how to correct this?
Try contacting them here:
There is a recovery method for that. See Secure Your Account with Two-Factor Authentication | Plex Support.
Unfortunately, I never got so far in the 2FA setup to get the QR image. So, no recovery codes were ever received. I do not understand how or why my account now shows the 2FA as enabled. Is there any way to reverse this?
This just takes me back to the Plex Forum. I do not see any place that Plex offers support.
Your account shows the 2FA connection was successful. If there was an error, it happened with your authenticator. Read the article I mentioned above. There is a way to receive a recovery code from Plex. Do it once to gain sign into your account, then do it a second time to get another code to remove the 2FA.
This has gotten me a little farther. I am now logged in to my PMS account and I see where the 2FA is active. When I click on “Edit” I receive two choices - Disable or Generate New Recovery Codes. Both selections require a verification code. Where do I get a verification code if my authenticator app was never connected to Plex?
I have it. I did not realize a recovery code and a verification code could be the same thing. I have now disabled 2FA on my account and will look in to re-setting it up. Thanks for your help, I appreciate it!
