Hello I forgot my Plex pin to my admin account and now I’m currently locked out of my account. When I try to reset the pin it asks for a verification code but I don’t remember setting up 2 Factor Authentication, How can I reset my Pin?
You did enable 2FA, on November 4th.
When I check my Authenticator app I used every code and neither of them worked is there a way I can reset it? To sign in i’ve been using the email temporary code to sign in
You might want to check the 2FA FAQ in the related support article.
This also explains how to use the recovery codes, removing 2FA as well as other options.
