Good day,
I forgot my pin and im the admin on the server if I go to forgot pin I cant reset it because I have 2 FA turned on on my account so now im locked out of my server is there any other way to work around this ??
Good day,
Hmm. yeah I think that form should have a 2fa code field. But if you have 2FA set up then enter password as passwordcode so if your password was secret and the 2FA app says current code is 234567 then enter secret234567 in the password field and that should work
It worked thank you very much
