Remove Seasonal Playlist option is gone
Server Version#: 1.25.5.5492
Player Version#: NA
Settings - Manage - Library does not reflect “seasonal playlist.” I do not want to see libraries such as “love is in the air” in my library, especially if I don’t authorize it. How do I remove without a choice in the settings management tool?
Are you sure you’re looking in the correct place? You need to hover over the library and then click “Manage Recommendations” for the list to appear. You should then see something like this:
You should then be able to de-select the “Seasonal Movies” “Home” option to have that hub removed from your home screen.
