it said it was unable to connect to remote server
That’s not a screenshot!
And the word Remote Server is interesting here, regarding claiming…
So please do as I said, and provide a screenshot, as well as explain Remote
Cool, and that means we can’t reach the PMS server on the IP you entered
So can I get a screenshot of everything please!
Also still needs to explain Remote
And since on Windows, do run it on the server itself, and as IP, enter 127.0.0.1
I have no idea why it says remote myself either. so I cannot explain it to you on why I am getting that message.
Still needs a full screenshot, instead of a snip from the bottom!
As well as you try to run it on the server, and use 127.0.0.1
of the claimit? the only other information is my login and IP address.
And that’s the key I’m looking for!
Now please PLEASE do as I say!!!
But…
I asked you to run it directly on the server, and use 127.0.0.1 as the IP!
Do above, and upload new screenshot!
I did that as well and got the same message.
Hmmm…That means your PMS is not running at all, so back to @OttoKerner here
Thanks for trying.
Take a look into the task tray.
Is the Plex logo there, and if it is, does it stay if you move your mouse over it?
