Renaming and removing Extras without Plex dance
Server Version#: 1.21.4.4079-1b7748a7b
Player Version#: 1.28.0.1681-cc6e807c
I just have a quick question about Extras and Featurettes. I tried using the inline method by adding “-featurette” to the file name, but it always showed up as a another version of the same file. The only way to play it would be to use the “Play Version” option.
So recently, I tried the “Featurettes” sub folder method instead which has been working. It displays the main video like it should and then below the credits it shows the “Extras” which is perfect.
Old Way that didn’t work:
…\Movies
----…\Movies\Some Movie (1980)
--------…\Movies\Some Movie (1980)\Some Movie (1980).mkv
--------…\Movies\Some Movie (1980)\Some Movie [Director’s Cut]-featurette (1980).mkv
New way that does work:
…\Movies
--------…\Movies\Some Movie (1980)\Featurettes
------------…\Movies\Some Movie (1980)\Featurettes\Some Movie [Director’s Cut] (1980).mkv
The issue I’m having is that I can’t seem to remove or rename Extras once they’re added. I need to rename some of them but it doesn’t seem to work. It shows the old filename and when I click on it, it fails to play because it can’t find it.
IE: I rename this:
…\Movies\Some Movie (1980)\Featurettes\Some Movie [Director’s Cut]-featurette (1980).mkv
To this, since the “-featurette” part of the filename isn’t needed:
I also tried removing the entire Featurettes sub-directory, rescan and then put it back. But it still shows the original name and won’t update the extras. I would prefer not to have to plex dance the whole movie folder just to update the Extras if possible.
Is there anyway to update the Extras without doing a Plex dance on the entire movie?
When you make changes to a movie’s extras, you should only need to refresh metadata on the movie for them to be recognized.
Hmm, I removed the Featurettes completely and then tried to scan and refresh metadata, but it still shows. How can I remove the extras entirely?
For example, I have a movie that’s in color and black & white. I set the B&W one as a “Featurette”. But I can’t seem to remove it after it’s been added:
I completely removed the B&W version, there’s only the color version on the drive now. After scan and refresh metadata, it still shows up like in the pic above. If I try to play it, it says the file is not found, since it has been removed - but still shows up as if it’s still there.
Empty Trash
Clean Bundles
Optimize Database (for extra cleanliness)
