Renaming folders and files with out plex treating them as new additions
so I have been slowly starting to rename my movies to include the imdb id.
but when I do that plex acts as if the movie is new.
is there a way to have plex not do that?
Settings > Library > disable Empty trash automatically after every scan
Rename your folder, rescan your library and Plex will detect the new location but not remove the old one. Go to Get Info menu and see if the new and old paths are there. If yes, then you can manually empty trash.
thanks for the quick reply!
2 posts were split to a new topic: Use file names and subfolders?
can this thread be closed, since I keep getting other people adding to my post?
Thread closed at OP request.
