Repository for Plex Pass Updates
Hello,
I have Plex Media Server running as Ubuntu service with PMS on a Linux VM on a remote XIRVIK server . I used your instructions here (https://support.plex.tv/hc/en-us/articles/235974187) to enable repository updating for Ubuntu distributions. That’s working well to update the Public version of PMS.
Is there a Plex Pass Ubuntu repository as well? If so, what are the instructions for adding the repository. If not, what are the instructions for manually updating? I’m not very knowledgeable in Ubuntu, but I can follow terminal commands instructions .
Thanks.
allcaps
There is not currently a repository for the PlexPass Releases.
Alternatively, take a look at this script it will help you automate the process of downloading and installing PlexPass updates
See: https://github.com/mrworf/plexupdate
Thanks! Problem solved. :smiley:
You may already have the older versions on your computer if you ever installed them in the past. Take a look here:
\PlexData\Plex Media Server\Updates
Carlo
Is this in the roadmap?
If not, please make it a priority. I don’t know the details of creating an authenticated repository but there has to be a way to do it without using an unsupported third party script from GitHub.
