Hello Folks,
I just purchased Plex Pass so I can use it’s DVR capabilities. I poured through this site as well as others and I am not clear on the hardware I need. I already have Plex Server setup, I understand I need a tuner. Here is issue: I am receiving TV locally via FiOS. So I know cannot use OTA tuner. So it looks like I can use:
- HD HomeRun Prime, as Prime is the only one of the 3 HomeRuns that supports ‘digital cable subscription TV’
- Hauppauge WinTV-HVR-955Q as this is only one from Hauppauge that supports ‘Clear QAM Digital Cable TV’
Am I right so far?
Now, what are the differences on these? Looks like HD HomeRun has it’s own app. One downside that I saw is unlike the OTA HomeRuns, this one one show only Standard Def when streaming, no HD? True?
If so, will the Hauppauge be sufficient? I just want to be able to record to PC and steam to Fire Stick.
Again, I’m already setup with server so I know how that piece works and I plan to get NAS, etc.
Also, I see the DVR setting under Plex Setting on my PC. But when I go to Fire Stick on TV, I do not see DVR. I assume once this is all setup, I will be able to see my recordings in another link on Fire TV?
Thanks!!
Craig
