I am running Plex server from a Nvidia Shield, playing files from a directly attached USB drive. Anything I play looks like a low quality YouTube video, with artifacts and picture breakup constantly. The files are all 1080P HEVC/x264. When I check the information panel whilst playing a file, it says ‘Resolution or bitrate exceeds maximum allowed’ , with hardware transcoding. The file I am looking at now is showing a resolution of 718 x 388.
Under Settings > Video Quality > Home Streaming, I have it set to Maximum. For internet access my Shield is tethered to my mobile phone, but as these files are all local I am stumped as to why this is happening. Any suggestions?
Here is my log:
Life of Pi (2012): Direct Play is disabled
Nov 20, 2018 19:26:43.618 [25972] DEBUG - MDE: Life of Pi (2012): media must be transcoded in order to use the hls protocol
Nov 20, 2018 19:26:43.618 [25972] DEBUG - MDE: Life of Pi (2012): selected media 0 / 156
Nov 20, 2018 19:26:43.618 [25972] DEBUG - Streaming Resource: Calculated bandwidth of 4494kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
Nov 20, 2018 19:26:43.618 [25972] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Nov 20, 2018 19:26:43.619 [25972] DEBUG - Scaled up video bitrate to 3061Kbps based on 1.500000x fudge factor.
Nov 20, 2018 19:26:43.620 [25972] DEBUG - Scaled up video bitrate to 3061Kbps based on 1.500000x fudge factor.
Nov 20, 2018 19:26:43.622 [25972] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x388, audio channels to 2, quality to 45, disable video DS as 2147483647kbps is > the 1727kbps available, disable audio DS as 2147483647kbps is > the 169kbps available
Nov 20, 2018 19:26:43.622 [25972] DEBUG - Scaled up video bitrate to 3061Kbps based on 1.500000x fudge factor.
