Resolution problem index tight order titles tv series
Server Version#: 1.28.0.5999
Player Version#:ALL
Hi, my question is very easy, where can I set the index title for TV Series with or without the ARTICLES: THE
Now when I insert in Plex the series Inside the plex architechture the articles are cutted.
Please if is available a paramenter send me a info.
My best regards
Andrea From Italy
Dear OttoKerner,
Yeterday i try to change the hidden server settings, but, unfortunately, the scenario don’t change,
I Insert the Tv series “the Baby” bit is recognized Baby, a different sarie.
Any other suggestion?
Grazie from Italy
Andrea
The change will be only effective for items which are added “as new”. i.e. you may have to perform either the Plex Dance or create the whole library from scratch.
That is a wholly different issue.
Stick to the naming guide. Add the release year in particular.
Grazie… I Solve the problems following the info, destry and recreate the library.
perfect
Hello, Grazie fro the support, fast and resolutive. Very Well.
I read the web page :
My question is:
Is possible to use IMDB to obtain the right info or is possible insert in the “naming” only TMDB o TVDB
If not in a future can you verify if this source is availableand permit to use this other services.
Grazie
Grazie.
No, the IMDb is not used for series.
You can use it for movies, though.
