Server Version#: 1.19.5.3112
Player Version#: Occurs on both 4.29.7 and 5.0.12
I’ve just purchased a new 2020 model Samsung TV:
Model Code: QA75Q70TAWXXY
Software Version: 1115.5
I’m seeing an odd issue where video playback will freeze, but audio playback will continue. The video does eventually start playing again, but stutters more and more until finally the client throws an error claiming that the file format is unsupported. I’ve tried disabling Direct Stream/Direct Play to force transcoding, but the issue persists.
For what it’s worth, this same issue occurs on the non-preview version of the Plex Client app as well as this one. There’s a lot of posts about this on the forums, but no solution seems to exist. I’ve attached logs (4.7 MB) to this post (includes ones sent to the server from the client). Is anyone able to assist?
