Restore Managed Users?
Hi there,
This may be an often asked question but Im hoping there’s an answer: is it possible to restore a deleted user profile? I made the rookie mistake of joining another persons Home on their invitation, and was only able to recover by deleting my previous profile. I had created a managed home user, and would like to recreate the viewing / listening history / profile.
Any tips gratefully received…
Thanks!!
You don’t need to delete your old account… just leave their home
Edit:
You cannot recreate managed users and their profiles from one account to another.
Thanks Tom - unfortunately the managed user has been deleted. If I restore a database backup, will that restore the history of that user?
Hi Tom - is there any other way to restore the watched history of the deleted user?
Nothing that I’m aware of
The following can damage your database and make it unusable!
Please don’t attempt it if you don’t have any SQL experience and if you don’t have a backup copy of your database. (It is easy enough to fetch one, directly under Settings - Manage - Troubleshooting)
Theoretically, there is a way to edit the plex SQLite database directly, and change all account_id references (which are currently pointing to the user ID of the old managed user) to that ID of the new managed user.
But still I have to hear back for confirmation, if this is viable.
If you know SQL, you can do this relatively easy.
First, you determine the account_ids of the old and the new managed user, by inspecting the table accounts. The number is in the column ID.
Of main interest are the tables metadata_items_accounts and metadata_items_settings
(These affect the statistics and the ‘played’ items of the user.)
but there are still 10 other tables wtih a column account_id
The idea is to change all user_id values from the old managed user to that of the new managed user.
I still have to determine which ones are safe to edit and which ones are not.
So if it’s not terribly urgent, you’d rather wait a few hours.
