Restricting access to specific remote IPs makes LAN clients stream through WAN IP
Server Version#: v1.42.2.10156-f737b826c
Windows 11 Pro (64 bit)
I want to restrict the remote IPs that can access my Plex because the port is open and I figure it would better for security. I cannot blacklist or whitelist IPs or regions in my router (Netgear XR1000) AFAIK.
So I have edited the “Scope” tab of the Windows Defender firewall rule for PMS to whitelist the specific remote IPs used by my remote users. It works perfectly as intended and remote access works fine except for one issue I don’t understand…
When remote IPs are added under Scope, my LAN devices will no longer connect through LAN, but always through my WAN IP. Also, if I don’t add my WAN IP to the list of remote IPs, I cannot connect to my PMS at all.
  • No restrictions have been put on LAN IPs in “Scope”. I’ve also tried explicitly allowing the LAN IP range (192.168.1.0/24) without success. My PMS is on the LAN network of my own router connected to the ISP’s router (192.168.0.1).
  • I’ve tried editing the “Manual Servers” of the Plex client app to use the LAN IP of my PMS but that breaks the access entirely.
  • I’ve tried specifying 192.168.1.0/24 under Network > LAN Networks in the PMS but this is apparently only used for bandwidth restriction purposes. Same for enabling my WAN IP to be treated as LAN bandwidth.
Can anyone tell me why restricting remote IPs would make LAN clients use the WAN IP instead of LAN? Thank you so much.
