Server Version#: n/a
Player Version#: n/a
I’ve noticed the subtitles have stopped displaying on my Roku device. No subtitles for all videos. Only way to get subtitles is to rewind, click play…but they will only display for a few minutes (at most) and then will stop displaying again. Please advise.
I can only get subtitles to work on the roku client when captions are set to always on within the settings on the roku itself (outside of plex). Worth a try to see if it fixes your problem.
ooo! okay let me give this a try. wish i could remote in to the TV ;P.
Will update if this works or not. Thanks, Dokuro!
Hit *
You’ll see subtitles are enabled for ‘Replay’ - like when you back up and only for a short time.
Turn subs on or off via the * key - while a video is playing.
Yes - once enabled they’ll be on for everything on your Roku - hit * to adjust as necessary.
The change wasn’t exactly embraced by the Roku community, but Roku took care of that by removing the community - and just like Plex/TVDB - once a thing has been developed to perfection - all that’s left is for us to ‘get used to it’.
