ROKU: Playback Error
Server Version#: 1.41.7.9799 (Ubuntu 24.04)
Player Version#: 7.36.14.10147-675caeec-Plex (Client on Roku Ultra)
  • I have Plex Pass.
  • Roku Ultra & Plex Server are connected locally via Ethernet
  • Roku Ultra connected to a 1080p TV.
After upgrading my Plex Server (Ubuntu) to 1.41.7.9799, my Plex Client on Roku can no longer play TV shows recorded by Plex DVR using a HD Homerun HDHR4-2US nor watch live TV sourced from the HD Homerun. Every time I try to I get “Playback Error Playback has stopped due to multiple playback errors. Please check your connection and try again”. The DVR recordings and live TV are in 1080i format.
UPDATE: Having the same issue with many movies now too.
This is on my local network using a Roku Ultra via gigabit Ethernet, no WiFi involved. Android and Windows Plex Clients play the same content with no issues.
Here are the troubleshooting steps I have taken, none have resolved the issue:
  • Optimized the database
  • Performed Clean Bundles
  • Disabled Hardware Trans-coding (GTX 1050-TI)
  • Reinstalled NVIDIA drivers on the server
  • Set the HW decoder to use the AMD GPU in the CPU
  • Restarted Plex Server Service (multiple times)
  • Rebooted the computer running the Plex Server
  • Deleted codecs in the
    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs directory
  • Removed / reinstalled Plex client on Roku, performed a hard reboot of the ROKU after removing the Plex client by removing power from the Roku
  • Tried forcing direct play
  • Tried disabling direct play
  • Set local and remote quality to 4 mbps 720p to try and force trans-code to lower quality
I haven’t nuked Plex Server and reinstalled from scratch, hoping to avoid that headache.
Log file attached. Plex Media Server Logs_2025-05-25_09-29-24.zip (2.5 MB)
Suggestions?
Try the current beta, 1.41.7.9823 (release notes).
For Roku clients, Plex transcodes some audio formats to EAC3. PMS 1.41.7.9799 has a bug where transcoding fails. The bug is fixed in 1.41.7.9823.
Thank you! Installed the current beta as you suggested and I’m back in the game! Even got it fixed before the boss lady found out :laughing:
same here…woo I was getting nervous
