Server Version#:1.20.5.3600
Player Version#: 9.4.0 build 4190-50
Hi, All of a sudden one of my favourite series started to buffer. I checked and Plex was transcoding the stream (I got hw acceleration enabled). I checked other 2 episodes that I watched yesterday and the day before and they are now buffering too whereas they weren’t. By the time I’m writing this post the buffer has gone away but I still would like to know why is Roku transcoding the movies?
This is the output from the logs
Dec 22, 2020 21:29:59.220 [0x7fb4a4775700] DEBUG - [Transcode] Codecs: Testing with profile 'High'
Dec 22, 2020 21:29:59.220 [0x7fb4a4775700] DEBUG - [Transcode] Scaled up video bitrate to 15043Kbps based on 1.500000x fudge factor.
Dec 22, 2020 21:29:59.220 [0x7fb4a4775700] DEBUG - [Transcode] Clipped max bitrate to 9216Kbps based on client-requested limit
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: Selected protocol hls; container: mpegts
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: analyzing media item 3586
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: Direct Play is disabled
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: media must be transcoded in order to use the hls protocol
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: selected audio stream is not the first audio stream and direct play stream selection is not enabled
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: no direct play video profile exists for http/mkv/h264/ac3
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: Direct Streaming is disabled, so video stream will be transcoded
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: E2 - Accounts Payable: no remuxable profile found, so video stream will be transcoded
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] Codecs: testing h264 (decoder) with hwdevice vaapi
Dec 22, 2020 21:29:59.221 [0x7fb4a4775700] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
- I dont have Direct Play disabled it’s enabled for sure why is it saying Direct Play disabled?
- Can it be that the Roku cannot handle the format of the movie because of high bitrate or something and that’s why it transcodes?
Thanks! r
