Server Version#: 4.47.3
Player Version#: 9.4.0 build 4200-50
Hi, I’ve been constantly experiencing video transcoding on my Roku Stick + while I only play media locally. My settings are:
Direct Play: auto
Allow Direct Stream: true
Burn Subtitles: Automatic
On the Plex server side I got Direct play enabled
The error message I get for various moves is
Movie#1
Dec 26, 2020 13:54:57.699 [0x7fb477684700] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Dec 26, 2020 13:54:57.699 [0x7fb477684700] DEBUG - [Transcode] Selecting best audio stream for part ID 2626 (autoselect: 1 language: hu)
Dec 26, 2020 13:54:57.699 [0x7fb477684700] DEBUG - [Transcode] Audio Stream: 6698, Subtitle Stream: -1
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: Selected protocol hls; container: mpegts
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: analyzing media item 2623
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: Love at Second Sight (2019): Direct Play is disabled
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: Love at Second Sight (2019): media must be transcoded in order to use the hls protocol
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: Love at Second Sight (2019): no direct play video profile exists for http/mkv/h264/ac3
Dec 26, 2020 13:54:57.701 [0x7fb477684700] DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to codec ac3 when profile only allows mp3
Dec 26, 2020 13:54:57.702 [0x7fb477684700] DEBUG - [Transcode] MDE: Love at Second Sight (2019): selected media 0 / 2623
Dec 26, 2020 13:54:57.702 [0x7fb477684700] DEBUG - [Transcode] Streaming Resource: Added session 0x7fb4946ebcd0:138d5d2f780f2be40b7209d43cfc6f4c
Dec 26, 2020 13:54:57.702 [0x7fb477684700] DEBUG - [Transcode] Streaming Resource: Reached Decision id=1433 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=2623 part=(id=2626 decision=transcode container=mpegts protocol=hls streams=(Video=(id=6697 decision=copy width=720 height=302) Audio=(id=6698 decision=transcode bitrate=241 encoder=libmp3lame channels=2 rate=48000))))
Dec 26, 2020 13:54:57.703 [0x7fb4a6222700] DEBUG - Completed: [192.168.1.152:58422] 200 GET /video/:/transcode/universal/decision?protocol=hls&mediaIndex=0&waitForSegments=1 (11 live) TLS GZIP 11ms 2385 bytes (pipelined: 8)
Frozen
Dec 26, 2020 13:45:57.232 [0x7fb475938700] DEBUG - [Transcode] Codecs: 10-bit HEVC test succeeded
Dec 26, 2020 13:45:57.233 [0x7fb475938700] DEBUG - [Transcode] Scaled up video bitrate to 53122Kbps based on 4.500000x fudge factor.
Dec 26, 2020 13:45:57.233 [0x7fb475938700] DEBUG - [Transcode] MDE: Selected protocol http; container: mkv
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: analyzing media item 2741
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Frozen II (2019): Direct Play is disabled
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Frozen II (2019): no direct play video profile exists for http/mkv/hevc
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Frozen II (2019): no direct play video profile exists for http/mkv/hevc/aac
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Frozen II (2019): no direct play video profile exists for http/mkv/hevc/eac3
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] Frozen II - video.colorTrc limitation applies: smpte2084 != bt709|bt470m|bt470bg|smpte170m|smpte240m|bt2020-10|bt2020-10 [list]
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Frozen II (2019): no remuxable profile found, so video stream will be transcoded
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Dec 26, 2020 13:45:57.234 [0x7fb475938700] DEBUG - [Transcode] Codecs: testing hevc (decoder) with hwdevice vaapi
Dec 26, 2020 13:45:57.235 [0x7fb475938700] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
Could this be a Roku limitation? If I force Direct Play sometimes it plays but there is no audio. I also have Direct Play enabled but it still says that it’s disabled.
If I play the same movie from my Plex app on my iPhone then Direct Play is working also if I stream it through my Chrome Cast then its all good too.
If I set Directly Play to force on the Roku it plays but no audio as described above and getting the following message
Thanks!
