I found two major issues:
- There’s another, unaccounted for, certificate floating around which is making the communications stutter badly. It has to reset each time causing delays.
Nov 12, 2019 21:26:20.976 [0x35b6f450] DEBUG - Created thumbnail of size 283x159, has pixels: 1
Nov 12, 2019 21:26:20.991 [0x2fd33450] DEBUG - Completed: [10.5.69.33:33972] 200 GET /photo/:/transcode?url=%2Flibrary%2Fmetadata%2F67986%2Fthumb%2F1553237933 (11 live) TLS 839ms 13209 bytes (pipelined: 1)
Nov 12, 2019 21:26:33.969 [0x2f9d3450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:33.972 [0x2fd33450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:34.167 [0x2f9d3450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:34.174 [0x2fd33450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:35.237 [0x313c3450] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 12, 2019 21:26:35.237 [0x313c3450] DEBUG - HTTP simulating 408 after curl timeout
Nov 12, 2019 21:26:35.237 [0x313c3450] ERROR - SSDP: Error parsing device schema for http://169.254.11.27:63444/upnp/xml/devices/ManageableDevice1.xml
Nov 12, 2019 21:26:35.245 [0x313c3450] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://169.254.10.229:49153/description.xml
Nov 12, 2019 21:26:35.246 [0x313c3450] DEBUG - HTTP requesting GET http://169.254.10.229:49153/description.xml
Nov 12, 2019 21:26:35.454 [0x2fd33450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:39.227 [0x2f9d3450] DEBUG - Completed: [10.5.69.37:37410] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (15 live) TLS GZIP 20017ms 5 bytes (pipelined: 16)
Nov 12, 2019 21:26:39.422 [0x2f9d3450] DEBUG - Auth: authenticated user 1 as thockin
Nov 12, 2019 21:26:39.423 [0x398bf450] DEBUG - Request: [10.5.69.37:37410 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (15 live) TLS GZIP Signed-in Token (thockin)
Nov 12, 2019 21:26:39.426 [0x398bf450] DEBUG - Content-Length is -1 (of total: -1).
Nov 12, 2019 21:26:40.689 [0x2f9d3450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:40.702 [0x2fd33450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:40.897 [0x2f9d3450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:40.908 [0x2fd33450] DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Nov 12, 2019 21:26:50.257 [0x313c3450] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 12, 2019 21:26:50.257 [0x313c3450] DEBUG - HTTP simulating 408 after curl timeout
- There is other activity, Transcoding perhaps(?), which is causing the whole NAS to slow down. These are occurring while it’s attempting to stream.
Nov 12, 2019 22:36:03.852 [0x334ed450] DEBUG - Setting container serialization range to [0, -1] (total=307)
Nov 12, 2019 22:36:03.869 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34337] 200 GET /hubs/home/recentlyAdded?type=1 (16 live) TLS GZIP Page 0--1 93ms 526 bytes (pipelined: 4)
Nov 12, 2019 22:36:03.877 [0x2fd33450] DEBUG - Auth: authenticated user 1 as thockin
Nov 12, 2019 22:36:03.881 [0x37c8d450] DEBUG - Request: [10.5.69.33:34337 (Subnet)] GET /hubs/home/recentlyAdded?type=1 (16 live) TLS Page 0-11 GZIP Signed-in Token (thockin)
Nov 12, 2019 22:36:03.881 [0x307a8450] DEBUG - It took 140.000000 ms to retrieve 200 items.
Nov 12, 2019 22:36:03.888 [0x37c8d450] DEBUG - Setting container serialization range to [0, 11] (total=-1)
Nov 12, 2019 22:36:03.957 [0x3387a450] WARN - SLOW QUERY: It took 260.000000 ms to retrieve 10 items.
Nov 12, 2019 22:36:03.981 [0x398bf450] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 10 items.
Nov 12, 2019 22:36:04.011 [0x3387a450] DEBUG - Setting container serialization range to [0, -1] (total=-1)
Nov 12, 2019 22:36:04.015 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34334] 200 GET /hubs/home/continueWatching (16 live) TLS GZIP Page 0--1 254ms 522 bytes (pipelined: 5)
Nov 12, 2019 22:36:04.042 [0x2fd33450] DEBUG - Auth: authenticated user 1 as thockin
Nov 12, 2019 22:36:04.045 [0x3ba5b450] DEBUG - Request: [10.5.69.33:34334 (Subnet)] GET /hubs/home/continueWatching (16 live) TLS Page 0-2 GZIP Signed-in Token (thockin)
Nov 12, 2019 22:36:04.046 [0x398bf450] DEBUG - Setting container serialization range to [0, -1] (total=-1)
Nov 12, 2019 22:36:04.059 [0x2fd33450] DEBUG - Completed: [10.5.69.33:34336] 200 GET /hubs/home/onDeck (16 live) TLS GZIP Page 0--1 289ms 520 bytes (pipelined: 4)
Nov 12, 2019 22:36:04.060 [0x37c8d450] WARN - SLOW QUERY: It took 250.000000 ms to retrieve 12 items.
Nov 12, 2019 22:36:04.062 [0x316b1450] DEBUG - Setting container serialization range to [0, -1] (total=1088)
Nov 12, 2019 22:36:04.063 [0x37c8d450] DEBUG - Setting container serialization range to [0, 11] (total=307)
Nov 12, 2019 22:36:04.068 [0x2f9d3450] DEBUG - Auth: authenticated user 1 as thockin
Nov 12, 2019 22:36:04.071 [0x3387a450] DEBUG - Request: [10.5.69.33:34336 (Subnet)] GET /hubs/home/onDeck (16 live) TLS Page 0-0 GZIP Signed-in Token (thockin)
Nov 12, 2019 22:36:04.071 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34339] 200 GET /hubs/home/recentlyAdded?type=8 (16 live) TLS GZIP Page 0--1 280ms 527 bytes (pipelined: 2)
Nov 12, 2019 22:36:04.077 [0x2fd33450] DEBUG - Auth: authenticated user 1 as thockin
Nov 12, 2019 22:36:04.080 [0x334ed450] DEBUG - Request: [10.5.69.33:34339 (Subnet)] GET /hubs/home/recentlyAdded?type=8 (16 live) TLS Page 0-11 GZIP Signed-in Token (thockin)
Nov 12, 2019 22:36:04.086 [0x334ed450] DEBUG - Setting container serialization range to [0, 11] (total=-1)
Nov 12, 2019 22:36:04.117 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34337] 200 GET /hubs/home/recentlyAdded?type=1 (16 live) TLS GZIP Page 0-11 238ms 3340 bytes (pipelined: 5)
Nov 12, 2019 22:36:04.158 [0x307a8450] DEBUG - It took 530.000000 ms to retrieve 414 items.
Nov 12, 2019 22:36:04.197 [0x3ba5b450] DEBUG - It took 200.000000 ms to retrieve 10 items.
Nov 12, 2019 22:36:04.253 [0x3ba5b450] DEBUG - Setting container serialization range to [0, 2] (total=-1)
Nov 12, 2019 22:36:04.255 [0x3387a450] WARN - SLOW QUERY: It took 210.000000 ms to retrieve 10 items.
Nov 12, 2019 22:36:04.273 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34334] 200 GET /hubs/home/continueWatching (16 live) TLS GZIP Page 0-2 229ms 1581 bytes (pipelined: 6)
Nov 12, 2019 22:36:04.287 [0x3387a450] DEBUG - Setting container serialization range to [0, 0] (total=-1)
Nov 12, 2019 22:36:04.293 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34336] 200 GET /hubs/home/onDeck (16 live) TLS GZIP Page 0-0 224ms 1401 bytes (pipelined: 5)
Nov 12, 2019 22:36:04.316 [0x334ed450] DEBUG - Setting container serialization range to [0, 11] (total=1088)
Nov 12, 2019 22:36:04.328 [0x2f9d3450] DEBUG - Completed: [10.5.69.33:34339] 200 GET /hubs/home/recentlyAdded?type=8 (16 live) TLS GZIP Page 0-11 249ms 6096 bytes (pipelined: 3)
Nov 12, 2019 22:36:04.358 [0x307a8450] DEBUG - It took 340.000000 ms to retrieve 322 items.
That little ARMv7 CPU is working as hard as it can. The scanner is also running.
I believe the SSL resets are inducing enough delay to push it over the edge.
All these photos are being added. It can’t do everything.
Nov 12, 2019 19:36:54.845 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-012.jpg"
Nov 12, 2019 19:36:54.845 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-119.jpg"
Nov 12, 2019 19:36:54.846 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-128.jpg"
Nov 12, 2019 19:36:54.846 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-102.jpg"
Nov 12, 2019 19:36:54.846 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-067.jpg"
Nov 12, 2019 19:36:54.846 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/2003/2003_Burning_Man/BM03-039.jpg"
Nov 12, 2019 19:36:54.851 [0x3274b450] DEBUG - Streaming Resource: Usage: 0kbps of WAN bandwidth, 0 streaming transcode slots, and 0 static transcode slots across 0 sessions
Nov 12, 2019 19:36:54.896 [0x30021450] DEBUG - Skipping over directory '2003/2003_Burning_Man', as nothing has changed; removing 141 media items from map.
Nov 12, 2019 19:36:54.897 [0x30021450] DEBUG - Activity: updated activity 360e8461-7d4d-401e-ae19-ee8b85770567 - completed 50.0% - Scanning Photos
Nov 12, 2019 19:36:54.897 [0x30021450] DEBUG - Scanner: Processing directory /volume1/photo/1996 (parent: yes)
Nov 12, 2019 19:36:54.897 [0x30021450] VERBOSE - * Noting that '1996' was updated at 2015-10-18 14:26:20
Nov 12, 2019 19:36:54.898 [0x30021450] VERBOSE - * Taking directory '1996' (651) out of the map (120 left)
Nov 12, 2019 19:36:54.908 [0x30021450] VERBOSE - Adding subdirectory for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita"
Nov 12, 2019 19:36:54.909 [0x30021450] DEBUG - Skipping over directory '1996', as nothing has changed; removing 0 media items from map.
Nov 12, 2019 19:36:54.910 [0x30021450] DEBUG - Scanner: Processing directory /volume1/photo/1996/2nd_Suburb_Players_Evita (parent: yes)
Nov 12, 2019 19:36:54.911 [0x30021450] VERBOSE - * Noting that '1996/2nd_Suburb_Players_Evita' was updated at 2015-10-18 14:26:20
Nov 12, 2019 19:36:54.911 [0x30021450] VERBOSE - * Taking directory '1996/2nd_Suburb_Players_Evita' (652) out of the map (119 left)
Nov 12, 2019 19:36:54.911 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/ADAMHAIR.JPG"
Nov 12, 2019 19:36:54.911 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/LOGO1.JPG"
Nov 12, 2019 19:36:54.912 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/ALLTHREE.JPG"
Nov 12, 2019 19:36:54.912 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/RAINBOW1.JPG"
Nov 12, 2019 19:36:54.912 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/THE_END2.JPG"
Nov 12, 2019 19:36:54.912 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/FOUNDATN.JPG"
Nov 12, 2019 19:36:54.912 [0x30021450] VERBOSE - Adding file for scanner: "/volume1/photo/1996/2nd_Suburb_Players_Evita/CHE_EVA.JPG"
