Synology DS220j chokes with Plex roku client
Server Version#: 1.22.3.4523-6000
Player Version#: 6.7.24.7009.0d0d064dd-Plex
I own a Synology DS220j. The Plex client works flawlessly with my Apple TV. However, when using the Roku TV client, it absolutely chokes. I am only trying to stream in 1080p, from ripped Blu-rays. Video from 480p DVDs works fine on both the Apple and Roku clients. I have tried changing settings according to some articles I have found in the web, but nothing seems to work. All movies are encoded with MakeMKV. When I attempt to play on the Roku client, the movie takes about 15-30 seconds to load, and then buffers another one or two times, and then I get an error message that the server is not strong enough to stream. But with the Apple client everything works perfectly.
Is the video transcoding when you use the Roku?
Monitor playback via Plex Dashboard → Now Playing. Expand the view to show details.
Is the Roku local or remote? Make sure it lines up with what is shown in the dashboard. If the Roku is local but the dashboard shows the connection as remote or indirect, then you’ve a configuration issue to work out. If the Roku is remote and the connection shows as indirect, then remote access is not working correctly.
If you’re using subtitles, try turning them off. Also, choose an audio format that direct plays if possible. Try AC3/Dolby Digital or dts. TrueHD transcodes on many clients.
The Dashboard is showing local, as to be expected. I am not using subtitles. Audio format is AC3.
Thanks for the info.
When you see the “server not strong enough” message it may indicate that the video is transcoding. Your NAS has limited transcoding ability and may not be able to handle the load.
If this is happening, you need to figure out why the video is transcoding and, if possible, avoid the situation.
The log files should provide additional information. Please pull them when you have a chance.
Also, what Roku model are you using (I forgot to ask earlier)?
  1. Configure your server for debug, not verbose, log files.
    See Reporting Issues with Plex Media Server for details.
  2. With no other streaming on the server, play one of the problematic movies until you receive the error message.
  3. Stop playback, wait 1 minute.
  4. Download the log files (Settings → Troubleshooting) and upload the entire ZIP file to the thread (Drag it into the message window. It will insert at the cursor location.).
Thanks for your help. I tried disabling transcoding, but then the file wont play at all in the Roku client.
Plex Media Server Logs_2021-05-15_14-03-36.zip (6.4 MB)
I get an error message stating "app cannot directly play this item, direct play is disabled.
The logs are attached.
go here and get this:
https://mediaarea.net/en/MediaInfo/Download
Paste a media report from the misbehaving file (since you didn’t bother to mention what it was) here so we can look at it.
Like this (use Preformatted Text):
General
Unique ID                                : 86803659635025510772592807683433360649 (0x414DC6D84248ECB8CBF1C571BC7AED09)
Complete name                            : G:\TV - Sci-Fi\Star Trek Enterprise\Season 01\Star Trek Enterprise - S01E01 - Broken Bow.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 1 018 MiB
Duration                                 : 1 h 26 min
Overall bit rate                         : 1 638 kb/s
Encoded date                             : UTC 2020-06-29 21:42:10
Writing application                      : Lavf58.42.100
Writing library                          : Lavf58.42.100
ErrorDetectionType                       : Per level 1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main@L4@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 1 221 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Original frame rate                      : 23.976 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Stream size                              : 759 MiB (75%)
Writing library                          : x265 3.2.1+1-b5c86a64bbbe:[Windows][GCC 9.2.0][64 bit] 8bit+10bit+12bit
Encoding settings                        : cpuid=1064959 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=5 / lookahead-slices=6 / scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=16 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / no-signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=0 / subme=0 / merange=57 / temporal-mvp / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=2 / selective-sao=0 / early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=1250 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : Identity
matrix_coefficients_Original             : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 239 MiB (23%)
Writing library                          : Lavc58.77.101 ac3_fixed
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Menu
00:00:00.000                             : :00:00:00.000
00:04:09.124                             : :00:04:09.082
00:20:35.067                             : :00:20:34.942
00:30:53.226                             : :00:30:53.226
00:44:04.142                             : :00:44:04.016
00:52:54.922                             : :00:52:54.838
01:00:25.247                             : :01:00:25.247
01:12:06.030                             : :01:12:05.988
01:25:47.893                             : :01:25:47.851
Log entry: Device is Roku (49" TCL Roku TV)
The movie is 2001: A Space Odyssey. It is VC-1/1080p.
The problem is the video is transcoding and the server is not powerful enough to transcode 1080p VC1 video.
However, I also noticed in the logs that the server is transcoding MPEG2/480p video (it does have enough CPU for that).
@JuiceWSA Thanks for jumping on the thread.
I don’t have a Roku.
Shouldn’t a Roku direct play MPEG2 video w/ AC3 2.0 audio - a DVD rip?
Doesn’t a Roku have some settings about enabling/disabling direct play/direct stream?
Any other device settings that could cause a video transcode?
media info.txt (25.7 KB)
General
Unique ID : 23196055941444432734604462976134711601 (0x117365DB001A4D8BF60B78512F1A8931)
Complete name : E:\bluray\2001 A Space Odyssey\2001 A Space Odyssey.mkv
Format : Matroska
Format version : Version 2
File size : 21.9 GiB
Duration : 2 h 28 min
Overall bit rate : 21.1 Mb/s
Encoded date : UTC 2021-05-09 17:13:34
Writing application : MakeMKV v1.16.3 win(x64-release)
Writing library : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release)
Summary
Video
ID in the original source medium : 4113 (0x1011)
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Bit rate : 13.4 Mb/s
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.269
Stream size : 13.9 GiB (63%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 477 MiB (2%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
ID in the original source medium : 4353 (0x1101)
Format : PCM
Format settings : Little / Signed
Codec ID : A_MS/ACM / 00000001-0000-0010-8000-00AA00389B71
Bit rate : 4 608 kb/s / 4 608 kb/s
Frame rate : 30.000 FPS (1600 SPF)
Bit depth : 16 bits
Stream size : 4.79 GiB (22%)
Language : English
Default : No
Forced : No
Audio #3
ID in the original source medium : 4354 (0x1102)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Language : French
Default : No
Forced : No
Audio #4
ID in the original source medium : 4355 (0x1103)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Language : Spanish
Default : No
Forced : No
Audio #5
ID in the original source medium : 4356 (0x1104)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Language : German
Default : No
Forced : No
Audio #6
ID in the original source medium : 4357 (0x1105)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Language : Italian
Default : No
Forced : No
Audio #7
ID in the original source medium : 4358 (0x1106)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Language : Spanish
Default : No
Forced : No
Audio #8
ID in the original source medium : 4359 (0x1107)
Format : AC-3
Format settings : Dolby Surround
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Stream size : 204 MiB (1%)
Title : Stereo
Language : English
Default : No
Forced : No
Text #1
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 58 min
Bit rate : 16.7 kb/s
Count of elements : 1284
Stream size : 14.2 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
ID in the original source medium : 4609 (0x1201)
Format : PGS
Duration : 2 h 15 min
Bit rate : 15.1 kb/s
Count of elements : 1300
Stream size : 14.7 MiB (0%)
Language : English
Default : No
Forced : No
Text #3
ID in the original source medium : 4610 (0x1202)
Format : PGS
Duration : 2 h 20 min
Bit rate : 12.0 kb/s
Count of elements : 1264
Stream size : 12.0 MiB (0%)
Language : French
Default : No
Forced : No
Text #4
ID in the original source medium : 4611 (0x1203)
Format : PGS
Bit rate : 15.6 kb/s
Count of elements : 1290
Stream size : 15.6 MiB (0%)
Language : German
Default : No
Forced : No
Text #5
ID in the original source medium : 4612 (0x1204)
Format : PGS
Bit rate : 16.4 kb/s
Count of elements : 1318
Stream size : 16.4 MiB (0%)
Language : German
Default : No
Forced : No
Text #6
ID in the original source medium : 4613 (0x1205)
Format : PGS
Bit rate : 14.4 kb/s
Count of elements : 1324
Stream size : 14.4 MiB (0%)
Language : Italian
Default : No
Forced : No
Text #7
ID in the original source medium : 4614 (0x1206)
Format : PGS
Bit rate : 15.2 kb/s
Count of elements : 1344
Stream size : 15.2 MiB (0%)
Language : Italian
Default : No
Forced : No
Text #8
ID in the original source medium : 4615 (0x1207)
Format : PGS
Bit rate : 13.4 kb/s
Stream size : 13.5 MiB (0%)
Language : Spanish
Default : No
Forced : No
Text #9
ID in the original source medium : 4616 (0x1208)
Format : PGS
Duration : 2 h 19 min
Bit rate : 11.0 kb/s
Count of elements : 902
Stream size : 11.0 MiB (0%)
Language : Dutch
Default : No
Forced : No
Text #10
ID in the original source medium : 4617 (0x1209)
Format : PGS
Bit rate : 12.1 kb/s
Count of elements : 1350
Stream size : 12.2 MiB (0%)
Language : Chinese
Default : No
Forced : No
Text #11
ID in the original source medium : 4618 (0x120A)
Format : PGS
Bit rate : 10.1 kb/s
Count of elements : 776
Stream size : 10.1 MiB (0%)
Language : Danish
Default : No
Forced : No
Text #12
ID in the original source medium : 4619 (0x120B)
Format : PGS
Bit rate : 9 799 b/s
Count of elements : 752
Stream size : 9.83 MiB (0%)
Language : Finnish
Default : No
Forced : No
Text #13
ID in the original source medium : 4620 (0x120C)
Format : PGS
Bit rate : 10.2 kb/s
Count of elements : 1328
Stream size : 10.3 MiB (0%)
Language : Korean
Default : No
Forced : No
Text #14
ID in the original source medium : 4621 (0x120D)
Format : PGS
Bit rate : 10.0 kb/s
Count of elements : 886
Stream size : 10.0 MiB (0%)
Language : Norwegian
Default : No
Forced : No
Text #15
ID in the original source medium : 4622 (0x120E)
Format : PGS
Bit rate : 13.5 kb/s
Count of elements : 1310
Language : Portuguese
Default : No
Forced : No
Text #16
ID in the original source medium : 4623 (0x120F)
Format : PGS
Bit rate : 14.6 kb/s
Count of elements : 1292
Stream size : 14.6 MiB (0%)
Default : No
Forced : No
Text #17
ID in the original source medium : 4624 (0x1210)
Format : PGS
Count of elements : 1272
Language : Spanish
Default : No
Forced : No
Text #18
ID in the original source medium : 4625 (0x1211)
Format : PGS
Bit rate : 9 113 b/s
Count of elements : 762
Stream size : 9.14 MiB (0%)
Language : Swedish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:02:57.093 : en:Chapter 02
00:04:39.112 : en:Chapter 03
00:11:39.865 : en:Chapter 04
00:16:57.850 : en:Chapter 05
00:19:52.941 : en:Chapter 06
00:25:28.693 : en:Chapter 07
00:27:37.989 : en:Chapter 08
00:29:29.434 : en:Chapter 09
00:33:45.857 : en:Chapter 10
00:41:08.549 : en:Chapter 11
00:45:37.401 : en:Chapter 12
00:50:56.303 : en:Chapter 13
00:54:43.029 : en:Chapter 14
00:58:33.635 : en:Chapter 15
01:03:55.915 : en:Chapter 16
01:06:04.961 : en:Chapter 17
01:12:10.576 : en:Chapter 18
01:18:51.727 : en:Chapter 19
01:23:01.393 : en:Chapter 20
01:27:01.966 : en:Chapter 21
01:27:49.264 : en:Chapter 22
01:30:07.568 : en:Chapter 23
01:32:50.565 : en:Chapter 24
01:38:35.326 : en:Chapter 25
01:40:46.874 : en:Chapter 26
01:45:35.454 : en:Chapter 27
01:49:41.241 : en:Chapter 28
01:55:19.579 : en:Chapter 29
01:57:05.935 : en:Chapter 30
02:01:28.114 : en:Chapter 31
02:11:33.135 : en:Chapter 32
02:17:57.519 : en:Chapter 33
02:20:33.425 : en:Chapter 34
I could not find any setting on the Roku TV that would enable/disable direct play/direct stream. These settings are only in the Plex client and server.
I should have been clearer. I meant in the Plex app on the TV.
… and now you see why Preformatted Text is so handy…
@FordGuy61 discovered the issue - Roku won’t Direct Play VC-1.
I have a dozen Rokus in play - and not one VC-1 steam - 'cause I know they won’t Direct Play and are converted to something that will.
Carry on.
Yes, the Roku Plex app has settings for direct play and direct stream. Changing these doesn’t make a difference
Is VC-1 an audio or video coded? How do I fix this?
It’s Video.
Handbrake… at my house ain’t no VC-1 gettin’ in here dressed like that…lol
Well… we convert the MKV File to an MKV file with a 264 or 265 Video Stream.
MP4s are so 2005
So convert the MKV file from MakeMkv into an mp4 in Handbrake?
Ok thanks for the help. I will get to it.
@aldomig_gmail_com
You’ll need to convert VC-1 video to H.264.
There are many tools to do this. Two of the more popular and free ones are Handbrake and XMedia Recode.
This should get you started:
In Handbrake, try the H.264 MKV 1080p30 preset.
  • Filter tab: Turn off all the filters.
  • Video tab: Change the video from 30fps to 23.976fps to match the movie.
  • Video tab: Change the Encoder Profile from Main to High.
  • Audio & Subtitle tabs: Pick the audio & subtitle tracks you want to passthrough.
Suggestion if I may?
remove all those subtitle tracks you will never use.
PMS having to sift through them does take CPU plus it wastes space.
Ohhhh - so that’s what made the report 9 blocks long…
Yea - I usually turn those off at the source, but… that’s me.
:wink:
