Romanian subtitles
Hi guys,
Romanian subtitles are showing wrong chars were diacritics are supposed to be.
What can I do to view them properly except to convert first subtitles in I do not know which format? Is there any improvement in plan for dealing with this issue?
Thank you
Most likely, your subtitle files are not in UTF-8 encoding
Check this one out:
If you use SubZero instead of the opensubtitles plugin, the conversion is automatically done as well.
install both
I do not know which one works but now is ok
thanks guys!
