Root directory on QNAP when setup new library
There is an unexpected error while loading the library.
Please contact our Forum
Now its showing the TV Shows again
Was just getting here. Yes, that’s what it says (kann Deutsch lesen)
Click the “MORE” (MEHR)
I have seen that before. Seems like it happens if Plex is in the middle of something. So it will probably clear up.
When in the middle of scanning, the newly added sections will be blank.
Click the Heim (home) and you will see server(s)
Each section will be listed.
Screenshot from 2020-10-16 17-18-44
thats all there is. Its coming and going!
Settings - Server - Troubleshooting (left side) - Download Logs
It will give you a ZIP file.
Please upload that here.
It seems only to be with this Series library. There was not something like this with Movies or even better with the MP3s.
Well the only time I remember seeing it was when the activity spinner was churning away on something. If that has stopped and it’s still happening then maybe there’s another issue on yours.
Plex Media Server Logs_2020-10-16_23-22-58.zip (8.8 MB)
in the terminal it says something like that
So, now the scan seems to be finished and the library shown is stable. But surprise, the same Show is again with english episode names. :frowning:
OK. So there must be a bug somewhere. It is the TV Show Baywatch. If I match it iwth the TVDB I will have everything in english (this is the only one, all others are in german with the TVDB) if I switch to the movie db it will change to German. Just with less Poster selections for the season covers.
Thank you for the logs.
Now I understand what is happening.
  1. Plex is matching media for everything in your TV-Series library section.
Oct 16, 2020 22:54:55.445 [0x7f2884390700] DEBUG - Completed: [127.0.0.1:37040] 200 GET /library/changestamp (15 live) GZIP 0ms 469 bytes
Oct 16, 2020 22:54:55.471 [0x7f2806bbe700] DEBUG - Request: [127.0.0.1:37044 (Loopback)] GET /library/changestamp (15 live) GZIP Signed-in Token (Homezone)
Oct 16, 2020 22:54:55.472 [0x7f2884390700] DEBUG - Completed: [127.0.0.1:37044] 200 GET /library/changestamp (15 live) GZIP 1ms 469 bytes
Oct 16, 2020 22:54:55.479 [0x7f286d11f700] DEBUG - Request: [127.0.0.1:37048 (Loopback)] PUT /library/metadata/473783/intro (15 live) GZIP Signed-in Token (Homezone)
Oct 16, 2020 22:54:55.481 [0x7f286d11f700] DEBUG - Scheduling an intro detection job for 473783
Oct 16, 2020 22:54:55.481 [0x7f2884390700] DEBUG - Completed: [127.0.0.1:37048] 200 PUT /library/metadata/473783/intro (15 live) GZIP 2ms 166 bytes
Oct 16, 2020 22:54:55.486 [0x7f2805d18700] ERROR - IntroDetector: Unable to run intro detection for item 473783 (library missing or disabled)
Oct 16, 2020 22:54:55.487 [0x7f280719a700] DEBUG - Request: [127.0.0.1:37052 (Loopback)] GET /library/changestamp (15 live) GZIP Signed-in Token (Homezone)
Oct 16, 2020 22:54:55.488 [0x7f2884390700] DEBUG - Completed: [127.0.0.1:37052] 200 GET /library/changestamp (15 live) GZIP 1ms 469 bytes
Oct 16, 2020 22:54:55.536 [0x7f2877fff700] DEBUG - Request: [127.0.0.1:37056 (Loopback)] GET /library/changestamp (15 live) GZIP Signed-in Token (Homezone)
Oct 16, 2020 22:54:55.537 [0x7f2884390700] DEBUG - Completed: [127.0.0.1:37056] 200 GET /library/changestamp (15 live) GZIP 1ms 469 bytes
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG -  * Season 6 (-1) Episode 19 (-1) (1900-01-01)
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG - Looking up season and index for an episode, indexKey=S06E19 dateKey=.
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG -    * Found episode with key S06E19
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG -  * Found episode s06e19
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG - Calculated media file path for path [upload://]: ["/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Metadata/TV Shows/d/b4c7144a1fee24c51e80f8fe1867e80fa656368.bundle/Uploads"]
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG - Calculated media file path for path [upload://]: ["/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Metadata/TV Shows/0/bbbf9bf98757794b4cd04c6da8a73341752761f.bundle/Uploads"]
Oct 16, 2020 22:54:56.288 [0x7f28065e2700] DEBUG - Migrating metadata settings from local://474901 -> com.plexapp.agents.thetvdb://70874/6/19?lang=en
Oct 16, 2020 22:54:56.290 [0x7f2874d61700] DEBUG - There were 2 top-level paths for The 100.
Oct 16, 2020 22:54:56.292 [0x7f286d40d700] DEBUG - There were 1 top-level paths for Friends.
Oct 16, 2020 22:54:56.295 [0x7f28065e2700] DEBUG - Doing expensive tags write for 'Forbidden Paradise (Part 1)' because something changed.
Oct 16, 2020 22:54:56.306 [0x7f286f447700] DEBUG - There were 1 top-level paths for Fear the Walking Dead.
  1. Your QNAP has the N3160 CPU. This CPU has limited speed. Scanning media (importing) does take time. The video must also be analyzed so Plex knows how to play it. (requires the most time)
Thanks for checking.
Now everything looks OK except the folder thing. But OK. For future librarys I will use then the /CACHDATA… Folder Tree instead the /share one.
For the Baywatch series it is still a mistery.
Using The TVDB I will have only english episode names and stuff instead of German. Using the Movie DB I have German in Episodes but the actors are different???
The question is now, is this a bug in Plex or is it a bug at the TVDB or MovieDB API?
