Running SEARCH for programs listed in the PROGRAM GUIDE
I have Plex Pass and a HD HomeRun Tuner. I have installed it and all seems good - it connects, can show Live TV and I can “program” recordings by selecting things in the Guide. The Guide is fine and tracks other guide data I have found.
My challenge is SEARCH. If I enter a Title or even part of a title into the search - i get responses from my Libraries and such - but NOT from the Guide data. I can even have a show in the Guide - execute search - and nothing from the guide - but it will find stuff from my Library.
Example: Bewitched. The show is listed in my guide and is set to run in the next hour. Search will show NOTHING under Live TV - but it will find the movie in my library and podcasts with the word.
What might be going wrong. I am running the latest Server (1.18.2,2041)
Is this in the web client? Which URL are you using?
I can confirm some wonkiness with search. Here’s some possible work arounds.
First, don’t hit return in the search field, but just let the results pop-up like this:
Capture2
Second, if you do hit return, make sure you scroll all the way to the bottom for possible results. Right now, even when initiating the search from the Guide, the correct results are at the very bottom without a very good visual indicator that more results are available.
Let me know if that helps at or not.
