Good day everyone!
The essence of the problem:
In the first Movies library, I select a movie, then click on the actor and go to the library page sorted by this actor.
Link:
https://app.plex.tv/desktop/#!/media/e2984b89a8d15a424ca4ff40e6ade8be2c7734a7/com.plexapp.plugins.library?source=8&key=%2Flibrary%2Fsections%2F8%2Fall%3Factor%3D26287&pageType=list
In the second Movies library (same settings), I select a movie, then click on the actor, but go to the actor’s page in the Discover section.
Link: https://app.plex.tv/desktop/#!/provider/tv.plex.provider.discover/details?key=%2Flibrary%2Fpeople%2F5d77683b85719b001f3a4d9b
Global search for an actor works correctly, as in the second library, sending me to the actor’s page in the Discover section.
Fixing the problems (database optimization, package cleanup) and updating all metadata of the first library does not fix the problem.
I have 3 Movie libraries and 2 Series libraries. Only 1 Movie library and 1 Series library work correctly, although they were created approximately at the same time.
Plex Server for Windows Version 1.40.4.8679
How can I change the incorrect (library filter instead of the Discover section) behavior of the library?
Compare the settings on the Advanced tab of each library’s properties.
See also the FAQ on this page: https://support.plex.tv/articles/discover-credits/
Done with comparing. Libraries have the same settings.
1st Movies library advanced settings:
- Scaner: Plex Movie
- Agent: Plex Movie
According to https://support.plex.tv/articles/discover-credits/ :
- Include adult content: Disabled
- The library uses a legacy metadata agent: No
- Items in a Plex Media Server library have not been refreshed: Metadata refreshed
2d Movies library advanced settings:
- Agent: Plex Movie
See if a complete DB rebuild can solve this issue.
You can use the .bat or the .ps1 file from this project (shut down Plex server before using them): PlexDBRepair/Windows at master · ChuckPa/PlexDBRepair · GitHub
Thanks a lot, OttoKerner!
.bat fixed the issue!
I have the same issue with actors and the Discovery section, but I’m using Plex on TrueNAS SCALE official App. From searching I can see everything about an actor, from the movie I see only movies with him inside the movie library. Looks like UI misdesign.
