Samsung 3.90.2 - Odd Behavior
Server Version#: 1.14.1.5488
Player Version#: 3.90.2 on Tizen 3.0
Update seems to be working good although I’ve noticed since upgrading shows are now transcoding more, before 100% of what I watched was Direct Play, now about 50% is Direct Play and the other half is transcoded… Also, Tautulli now recognizes my TV as the IP address of my router and not the IP of the TV. It has always shown it as the TV IP. Both of these issues started after the upgrade to 3.90.2, but to be clear everything is working good.
On the same version of plex on Q6 tv 2018.
I’m having problems with the search.
When I found the movie I want and click on it, the app freeze and I have to restart it. If I select the same movie from the liabrary it works fine.
I just can’t believe that you brought back the option to change the subtitles’ color.
Please, keep it!
Thanks.
Regards.
I have the same issue with my 2016 tv, exactly the same.Search is not working. For now i use 3.84.1 Preview. I also don’t understand why the subtitles size is different between movies and shows.
Excuse me but where can i download version 3.90.2? I can’t find it.
same question here, I was using 3.84.1 preview, then i have read on forum, that there should be new version available -> i am geting old 3.3.4 from samsung store… tizen 3.0 TV…
I’m not sure how/when it happens as it’s pushed to my TV’s.
Look in the Samsung APPS, find Plex and check that the version number is 3.90.2 and then download that.
