Samsung Smart TV can't connect to Plex
Server Version#:
Hi all, I recently bought a Samsung Series 8 RU8000 and downloaded Plex on it. It worked the first time I used it perfectly but now it suddenly can’t connect to my Plex Server on my computer. I haven’t changed any settings or anything since I used it.
On the Plex app there’s an exclamation mark next to ‘MynamePC’. I also have my friend’s sub account connected to my Plex and I can access all his stuff but not mine. It also works perfectly with my account if I play it through Chromecast on my phone or my PS4, but it would be much easier for me if it worked with the app.
I’ve tried a fair few things already including reinstalling the app on my tv, logging out/in on my PC, making sure Insecure Connections are set on ‘Always’ in my settings on the tv app, etc.
I’m pretty noob with all this stuff and have seen some people mention port forwarding and setting up a static IP etc but not too sure how to do that and not really hopeful that will even fix it.
Does anyone have any suggestions? Would be much appreciated.
Edit: Just forward my TV IP to Plex on my PC under Network, didn’t help.
Does your TV app have in settings, Manual Server. If so add the server LAN IP address and Port: 32400
Yes it does. I think it’s already there though, it says:
Connection 1 IP
Connection 1 Port. 32400
Connection 2 IP
Connection 2 Port. 32400
Server network settings, have you got secure connections - Preferred.
IPv6 not enabled
Add your Router’s IP address to List of IP addresses and networks that are allowed without auth Example: 192.168.0.1/24
Are you running a VPN, if so turn off.
I added my routers IP address.
Secure connections is set on Preferred.
The box is ticked that says “Enable server support for IPv6”
Save settings and restart all devices including Router, Untick IPv6
Still not working. It might work for little bit here and there but then it goes back to the exact same error…
This is happening to several people in the threads regarding Samsung Smart TVs. I have 3 Samsung Smart TVs and all but one don’t work. I am not exactly sure why the one still works as it is the oldest of the three I own. All my settings are still the same as before with one exception………the latest update from Plex.
Needless to say I have learned my lesson. I will wait a very long before I update my Plex software.
Yep it says on the support page that Samsung TV newer the 2016 are not supported anymore. They said to use Roko, Apple TV etc. only broken is that Plex is not on my Apple TV account to pick
