Samsung SmartTV 2019 playback error at 97%
Server Version#: 1.21.2.3943
Ubuntu 20.10
TV:
Player Version#: 5.7.1 Preview
TV Model: Q80R (2019) 55inch
Tizen Version#: 1374.0
Android:
Android Player Version: 8.12.2.22756
Model: Honor 10
Android Version: EMUI 10
I’m getting a playback error with every single episode of a series at 97% played (grabbed that from tautulli) of this particular type (4k). It has happend across seasons and does not occure if I restart playback 5min before end. Still happens when starting from 50% and 75%. Included mediainfo xml, plex xml and plex logs.
Hasn’t happend with other Players (tested android). Maybe issue with directplay, since my TV can’t handle DTS XLL and thus transcodes. or maybe chapter issue, which i dont think is the case, since the end-credits chapter starts 2-3 seconds after. Though the 2-3 seconds is (approx) consitent throughout all episodes.
s02e11.txt (6.3 KB) s03e10.txt (5.2 KB) plex.media.info.XML.txt (9.1 KB)
Logs_preview.zip (1.4 MB)
UPDATE:
Just tested non-preview (5.1.0) and error did not occure. Here are the logs of the non preview versionLogs_non-preview.zip (345.2 KB)
staying away from preview for now, but will go back as soon as its fixed (or my misconfig is solved)
I believe I am also experiencing this issue, although I’m not using a Preview build of Plex. I have been experiencing this issue on the Samsung Plex app ONLY – across many PMS updates since December.
Q65R Samsung Smart TV App here. Happening across many TV series, multiple file formats, with direct play/stream enabled and disabled.
